I live in an older house and have some outlets in our kitchen that don't make sense to me. We have one outlet that is tied to a dimmer switch on the opposite side of the room. I can detect that the outlet is hot using my voltage detector (when the dimmer switch is all the way on), but it pulses. I get about 6-7 beeps, then it skips one, beeps 6-7 more times, skips, continue. My GFCI tester shows an open hot. The outlet doesn't work.
I'm not very experienced with electrical work but this sounds highly unusual to me. Where should I start with fixing the issue?
