I've used adjustable wrenches for years but I still end up turning the wheel the wrong way half the time, widening the wrench when I need it narrow and vice versa until I figure out the orientation I'm holding it and do it correctly.
Is there an easy to remember shortcut way of knowing which direction to turn the wheel that I just never learned. For instance, when I grab an adjustable wrench from my bag, how can I quickly know based on the feel of the wrench in my hand or a quick glance that pushing the wheel up with my thumb will tighten or loosen the wrench without inspecting or fiddling with it for a few seconds.
This question assumes that most adjustable wrenches have the same wheel operation which probably isn't the case, however the 4 that I own work similarly to the one pictured. When held in this orientation it will widen when I push the wheel up with my thumb.
Would love to hear some suggestions. Thanks.
