I'm sure this is rudimentary, but I'm very inexperienced in anything practical with electronics. Would like to try to get a 3volt battery go run some LEDs. I thought I could just take two AAA batteries (1.5v each) and wire them in series to get approximately 3v.
So using some tape and solder I ran a (green) wire from the butt terminal of one battery to the head of the other:
I burned myself surprisingly few times in making this
However, when I try to test the voltage, I do not get what I expected
Multimeter shows only 1.63v
I thought hooking batteries together in series should double the voltage? What am I missing?
closed as off-topic by Tester101 Oct 2 '16 at 16:42
  • This question does not appear to be about home improvement within the scope defined in the help center.
If this question can be reworded to fit the rules in the help center, please edit the question.
  • Measure each battery individually, you can still do that with the wires you have added attached to the battery. I suspect your batteries don't have a full charge. Your logic is correct. – Tyson Oct 2 '16 at 16:04
  • @Tyson you are correct thank you, one of the batteries seems near 0 – George Mauer Oct 2 '16 at 16:06
  • This is not do-it-yourself home improvement related. – Tester101 Oct 2 '16 at 16:42
  • Soldering to batteries usually isn't good for them. 2AA and 2AAA battery holders are cheap and plentiful on ebay for future projects. – Grant Oct 3 '16 at 21:53
  • Thanks @Grant I was just playing around with this, but thanks for the advice. – George Mauer Oct 3 '16 at 23:04
