43
I need to replace a sump pump, but have run into a problem. The route for the cord goes through a 2" pipe with two 90 degree bends, and fish tape is ineffective. The pipe appears poorly jointed as well and uneven. Is there a way to get the cord through this convoluted pipe?
The old cord is already out of the pipe, and cannot be used to drag a pull string.
Getting a power cord through a pipe with many turns without fish tape
  • 10
    I once managed this by shoving a cheap metal tape measure through a pipe like that. The tape wants to stay straight but will buckle neatly at the bends and continue on it's way, then pull it back through with a cord attached.
    – Wossname
    Oct 2, 2016 at 9:41
  • 4
    I wonder if a sewer snake might work better.
    – Hot Licks
    Oct 3, 2016 at 1:38
  • @HotLicks I tried a sewer snake. No possible way. In fact even that cord end in the picture would not go through WITH a pull string, until I pulled another trick or two. -OP
    – Bryce
    Oct 4, 2016 at 15:09
8 Answers 8
93
This technique worked great. I tied a string to the cord, tied a plastic bag to the string, and sucked that bag right through the pipe using a vacuum cleaner.
plastic bag as fish tape alternative
Just be a little cautious: the bag can travel through the pipe in a blink of an eye, and you might not want to have to fish the bag out of the vacuum.
Once the bag is through, pull the cord through, and untie the string.
    Electricians have small foam plugs called "mice" that they use for this -- probably easier to work with than a plastic grocery bag. Oct 2, 2016 at 1:24
  • 7
    You can solve the problem of sucking the bad by using some sort of mesh at the end. Air-confitioner filters could work great with this. Also, for situations where the vacuum cleaner tube is too small, you can use a paper sheet with a hole smaller than the vacuum cleaner's tube diameter. Oct 2, 2016 at 11:41
    Or just duct-tape 2 pieces of rope in 'X' fashion to tube's exit if you don't have a mesh on hand. Oct 3, 2016 at 9:43
  • I've made a bullet to do this using the tapered part of a marker pen. A light ball (ping pong ball or smaller hollow ball from a toy) also works well. You can get more suction by removing fine filters from the vacuum, but keep something to protect the motor. There is an upper limit to the bends you can get round this way -- if it starts to resemble a coil, the fish string will pull tight.
    – Chris H
    Oct 3, 2016 at 13:02
    @ThreePhaseEel foam plugs have their place I suppose, but this is a DIY site, no? Gotta give a star or two for using materials on hand. This by the way took all of like 60 seconds start to finish, including finding the bag, it went very easy.
    – Bryce
    Oct 4, 2016 at 15:14
33
As a wireman with 30+ years of experience, I've had to do lots of tricks to complete the task. While a vacuum and rat (plastic bag) works most of the time, it sometimes fails for many reasons. You might want to go the opposite of that idea. Get some nylon string and a living rat from a local store. Be sure to size the rat for the specific size conduit. Get some compressed air from somewhere. I have known them to run 1/4 mile before. And the rat will go fast. Have a helper to dole out string as it enters the conduit. It's best to have a good lead laid out on the ground, because when you start, the first hundred feet will be run in seconds. Good luck 😎
  • 24
    Just remember to feed and water the rat and release it when finished.
    – Chloe
    Oct 2, 2016 at 21:21
    I've no idea if this would work consistently (what if the rat stays in the middle of the system?) but it's ingenious even if it doesn't.
    – enderland
    Oct 3, 2016 at 18:35
  • 19
    @enderland If that happens then you need to use an electricians snake to get the rat out.
    – Freiheit
    Oct 3, 2016 at 18:37
  • 7
    @Chloe That's silly - why would you simply release a rat after having gone through all the trouble of training it to pull cables through things?
    – Crashworks
    Oct 4, 2016 at 1:27
  • 8
    @djsmiley2k, yep, trained ferrets were used by Boeing to drag the pull cord for air liner wiring runs. I don't think they do it any more -- not since the Federal Ferret Workers' Union strike of 1964.
    – Wossname
    Oct 4, 2016 at 13:49
17
Another trick that works is to use weed-whacker line. It's essentially really thick monofilament and it turns corners better than fish tape. I've used a lot of it on my boat to pull wires.
  • Heavy fishing line might or might not also work; same idea.
    – keshlam
    Oct 3, 2016 at 0:38
  • PTFE-insulate wire as well.
    – Chris H
    Oct 3, 2016 at 13:03
9
In the past I have used
  • micro RC cars - tie the string to the body and drive.
  • hexbugs - (A hexbug is a small oscillating, buzzing "robot". The oscillation in combination with its flexible rubber legs makes it move.) tie a string to it (lightweight monofilament) and go for a cup of tea, come back when the bug has gone through the conduit
  • magnets - one tied to the end of the string one outside the wall to pull it through the pipe, doesn't work so well on ferrous pipes :D
  • hoover with a bag and string - as described above
  • small fishing float - tied to a light line, close the "bottom" end of the pipe, flood it and watch the float come up voila pipe traversed.
  • leaf blower and bag and string - similar to the vacuum, more fun to do though, and seems to develop more pressure for pushing the bag.
  • bearded dragon - put him in one end, release live food at the other and off he goes.....just remember to tie a light string to a harness or its basically just a fun run for your lizard! (guilty!)
Hopefully some of these can help you, maybe not the bearded dragon for that size of pipe though.
    Suction is limited to 1 atmosphere (which cannot be realized), while pressure is not. Same problem as pumping water up out of coal mines: pushing works better than pulling.
    – Yakk
    Oct 4, 2016 at 13:15
  • Thanks, never looked at why the leafblower was so good, but that certainly explains it:) I have tried industrial vacuum generators, with the sometimes funny side effect of collapsing the piping (not so funny when it has to be replaced, but makes the walls look rather cool:)
    – GMasucci
    Oct 4, 2016 at 13:25
  • @GMasucci : gecko. Have you ever tried a gecko? Of course that animal is nocturnal, so you'll have to tie the string, put him in, and he'll hide in the pipe until nightfall. Come out at night with a flashlight and grab him....
    – Bryce
    Oct 4, 2016 at 15:12
  • Lol not tried a gecko, though they can climb on just about any surface so might be worth a go, and I get a new pet out of it:)
    – GMasucci
    Oct 7, 2016 at 13:48
We just pulled 3 THHN-2 gage 2 (two power one neutral) and one THHN-2 gage 6 for ground through about 25 feet with two wide angle 90's (normal 90 degree but not abrupt) and one 45 degree. Luckily we put all the bells in the same direction. Even the wire would not go one way. We tried putting the fish wire in the other way and the pulling no luck even on the first 90 degree. All the bells were going one way so we were lucky. Then we put the fish wire the way it would go (easy way) and pulled a small nylon rope through. Then we did not use the fish wire again and used the thin nylon rope and pulled on the "easy" way. Went at about 2-3" per pull no problem. So there is an easy way to pull and an impossible way. The easiest way you get the fish wire though is the easiest for the wires as well. so you need to put fish wire through easiest way, then pull the rope though, then tie the rope with electric tape, then pull the way you got your original fish wire (easy way) through. At least that worked for us.
Had a vertical drop on an HVAC oval return duct with an S curve that had a 2 foot horizontal run. I used a real fishing pole and put a tiny fishing hook into a ping pong ball. I gave the line plenty of slack and dropped the ball in. After a few tries, it bounced through the S curve. I then used the fishing line to pull through a stronger small rope. I then used the stronger rope to pull the wire.
I use a rodding spring line aka drain cleaning cable that I use to unblock pipes to thread cables.
Here's your guide to lulling long runs. We typically do 150m plus runs in 100mm PVC, you have to tie string loops to one fish tape and feed in as far as you can. Then from the other side of the conduit you tie a hook end to your fish tape, and feed it in till you hook it up to the other one. Then just pull back and you're done. This saved us tons on these long runs. We use coat hanger wire to make hooks with.
