I have a garage door that started to act up by not closing completely, I ignored it (bad move on my part). It has now closed and will not open, I have tried the emergency release cable and it is now disengaged, still will not open. I can hear the motor running when I try the remote. I do not have a door into the garage and the windows are super small and high (I am 68 years old and not agile). Is there any way to force the door open ?? It also does not have a handle on the outside of the door making it difficult to get a grip on the door. Do I just have to trash the door and buy a new one? Any answers are appreciated.
Are you able to tell if the emergency release disengaged? Have you ever practiced using it from the outside? – Tyson Oct 2 '16 at 1:06
The emergency release cable on my garage door is inside the garage. When it is pulled, the door operates manually by lifting. If the springs are weak, it will take some effort to get the door moving.
You have two questions.
The first answer may be that your door has weak springs. A lever of some sort is indicated. Consider a two-by-four of some length, perhaps with a steel strap affixed to the end to get under the door. A fulcrum attached to the lever close to the end will give you some lifting to the door. Block the door at the height accomplished, then re-position the fulcrum, perhaps lengthening it to afford additional height. Block the door each time a gain is made. There are also devices known as fence post jacks which will allow straight vertical lifting once you have sufficient elevation to access the underside of the door. Even an old-style auto jack could be pressed into service, but I've not seen one of those in years.
At some point, you should be able to lift the door by hand, as the springs take over the load.
Rather than trashing the door should the above option be out of reach, consider to contact a garage door company for suggestions. With sufficient desperation, many other options are available. My neighbor has a bobcat type loader with fork-lift blades. If my door were stuck badly enough, it would certainly open under the force of the loader.
That leads my train of thought down another track. One could construct a simple set of wedges and tap them into place with a hammer. As the door began to lift, the wedges would be stacked onto additional spacers in order to continue the progress until the springs engaged.
If your release cable snapped and did not disengage the mechanism, it is necessary to perform the lift and remote actions together or risk damaging the opener. When my opener sheared the teeth on the motor, it was strong enough to prevent manual opening but not strong enough to lift the door. Had the release not operated properly, there would have been little to no additional damage to the already worn gear.
Good answer. Imho, the best parts are try leverage, then call a specialist. – Aloysius Defenestrate Oct 1 '16 at 21:10
Your first sentence raises doubt about the emergency release. It's likely arranged for outside use. There are many of these or similar in our area for detached garage. Making the emergency release available outside. – Tyson Oct 2 '16 at 1:04
I wasn't aware of the key aspect of an external release. With such a design, I can understand why there might be difficulty getting the door open. Knowing now the configuration, I would also suggest "rocking" the door up and down while activating the release, to facilitate removing a possible binding on the mechanism. There does not appear to be much travel, but one does not need much travel with sufficient mechanical advantage. The key lock design does not provide much mechanical advantage. The design puts the key at risk of breaking. – fred_dot_u Oct 2 '16 at 1:15
