I recently bought a 5-bulb track lighting & installed GU10 base MR16 shape, dimmable LED lights bought off of eBay. The lights started flickering after turning them on after a few seconds.
I thought it was due to the cheap bulbs & bought a 3-pack from HomeDepot. I swapped 1 bulb from the track & it looks like the flickering issue is gone.
Can someone explain whats going on here?
edit: Gu10 base, MR16 shape. Plain regular plug in socket.
Also, I would like to install a dimmer switch to this & I hear there are different kinds of them. Which one should I be buying?
Please let me know if you need any further details or if you want me to try something.
