Any advise on how to clean these floors after pulling up carpet would be great or is it time to just get a sander and refinish?
Much thanks in advance.
Charles
Sign up to join this communityAny advise on how to clean these floors after pulling up carpet would be great or is it time to just get a sander and refinish?
Charles
If you would like the floors to look nice pull the base boards and the tack strip. Rent a large belt sander from the local equipment rental store. Your floor doesn't look to be in two bad of shape and appears to have been oil finished so you may be able to use a less aggressive belts 220 maybe 400 grit. once the first pass is done start saving some of the sawdust, it cam be mixed with carpenters (white glue to form a paste) and fill the holes. Holes never take stain or finish the exact color of the surrounding wood but looks better than a divot in the wood. Oil finishes are much easier than varathane / polyurethane in my opinion but varathane / polyurethane finishes if done correctly are awesome. 1 more plus for oil finish is when the floor starts to show some wear some fresh oil brings the wood back to an almost new look in just a few minutes. The reason to pull the base boards so you can get close to the wall and they will need to be lowered to the floor level. When I do this I cheat by buying a wider baseboard so I don't have to paint the walls, I paint the baseboards outside then when dry attach them and cover the finish nail holes (I am a sloppy painter) so this saves me tons of time and the floors have looked great.
