For the past several months, my roommates and I have taken to enjoying varying builds of Dance Dance Revolution in the evenings, inclusive of X, MAX 2, and Supernova 2. I personally have gotten reasonably good at it, taking my game up to 7 and 8 difficulty in the earlier builds and as high as 11 in DDR X, barless (that is, without a safety bar).
Unfortunately, despite the fact that we live in a three story townhome with no neighbors above or below us, our neighbors on either side have complained about the noise during hours of play. Because we share walls with both sets of neighbors and our only practical locations are closer to one or the other, we can't minimize noise by setting the system up equidistant from both shared walls. And, as the shared walls have strong sound insulation, the noise being put out is relevant but not significant. The real problem is the vibration, which is an exceedingly common complaint about home installations.
After researching the issue, it came to my attention that foam inserts are a very common strategy to reduce vibration and audible noise. It is also possible that we can schedule our routine with either set of neighbors, but we'd like to be more courteous during normal waking hours if possible.
We currently own two Konami dance pads that we've modified with plastic chairmats and carpet tape to prevent slippage. I'm considering picking up a cheap memory foam topper from Amazon to place under the chairmats for single, versus, and doubles play, under the assumption that the high density of the material and low slippage should be sufficient for extended play at high difficulty.
Is this the best solution to the problem? What other methods of vibration baffling are available that I've not considered?
Crossposted from Gaming.SE.
closed as off topic by ChrisF May 25 '12 at 16:41
Questions on Home Improvement Stack Exchange are expected to relate to home improvement within the scope defined by the community. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about reopening questions here.If this question can be reworded to fit the rules in the help center, please edit the question.
Answered: gaming.stackexchange.com/a/41978/5935 – MrGomez Dec 16 '11 at 19:46
