Tell me more ×
I have a York Affinity condenser. When I run my heat pump, I expect it to turn on somewhere in the cycle but it doesn't. It generally does this once a year. The usual fix is to cycle the power of the ac and the furnace. This year, it didn't fix it and I have to use propane to heat the house.
Any ideas?
How cold is it outside when this happens? – BMitch Nov 1 '11 at 17:46
Have you tried whacking it with a hammer/wrench? – Tester101 Nov 1 '11 at 20:04
Happens at 30 degrees, up to 60 degrees, no heat. Whacked it. No joy. – asp316 Nov 1 '11 at 22:55
In extreme cold, e.g. 30 degrees, the heat pump loses all it's efficiency, so you should be on emergency heat (electric) or some other alternative at that point. The fact that it could be fixed with a power cycle indicates a possible issue with the controller. – BMitch Nov 4 '11 at 12:58
Know someone who can answer? Share a link to this question via email, Google+, Twitter, or Facebook.
