Tell me more ×
I'm installing shelving in my 5x5 kitchen pantry. My plan is to run 1x2 strapping on the back edge and left/right sides of each shelf, then use 1x12 boards as shelves. I'm considering poplar for the shelving materials.
I'm wondering if the side/back support will be sufficient or if I'll need a brace in the middle. We don't plan on putting too much weight on the shelves but I'd rather do the project once than have to come back to it later.
how deep are the shelves? 1" is pretty thin to span 5' but if they aren't too deep the back strapping may be enough. To be safe, I'd attach a 1x2 face to the front of the shelves to act as a front brace as well. Do note that stocking up on canned goods can create a lot of weight pretty quickly. – DA01 Oct 31 '11 at 13:58
@DA01 said exactly what I was going to say. I did a similar project, and running a 1X2 across the front also attached to a vertical 1X2 in the center has been quite sufficient for a lot of canned goods. It is not the most attractive shelving, but it does a great job for a pantry. – Tatton Chantry Oct 31 '11 at 15:27
I ended up putting an 8x12 metal bracket in the middle of each shelf except the bottom shelves which I just installed feet under them. The shelving is very strong and should never flex. – tmcallaghan Nov 9 '11 at 16:35
up vote 7 down vote accepted
Unsupported 1x12 over a 5' span will sag (even under its own weight). As an alternative you could get some of these shelf tracks (~$2.25/track)
photo of shelf track
and some 12" brackets (~$1.30/brace)
photo of bracket
and then lay your 1x12's on top to make the shelves. This option also allows you to easily adjust the shelves up and down, to suit your needs.
If you want to make the shelves completely from wood (as you suggest), you'll need to beef up the design and add additional supports.
With a 5' span, you'll want at least 3 braces per shelf (4 if heavier items are going to be stored on the shelf). – Tester101 Oct 31 '11 at 18:55
I have 1x12 shelving in my pantry area in which one wall is about 7'. Each board on the longer length is braced with three of what are sold as 'utility shelf brackets' in most hardware stores. They're not as fancy as the adjustable tracks that Tester101 referenced, but they tend to sell for about $1 each in the stores, and they allow the board to go fully against the back wall (as there's no upright in the way), making it easier to put a strip along the back to deal with sagging along the length of you ever have to. You also screw or nail the bracket into the shelf, so sagging is greatly reduced compared to just setting a board across a floating support.
The only issue with fixed shelves is that you have to know what sizes of things you're going to be storing. Mine are of differing heights; the bottom could hold a 2L bottle with an inch to spare (although, I keep them on their side in little cubbies, sized so it'll 64oz juice bottles or a double-wide stack of boxes of chicken stock). The others can hold a double-stack of 28oz cans with a couple inches to spare. I keep larger stuff up above (eg, large cereal boxes, rolls of paper towels), as those tend to be lighter things.
The only problem things are really small jars, where you're tempted to stack 'em 3 high, but I'm afraid of them falling over. That might not be a concern for most people, but my pantry space is along my basement steps, so I'm always afraid I'll hit 'em when carrying the laundry up & down ... other people likely won't have that concern ... but I still find 2 high means I don't have to dig through stuff to retrieve what I want.
(Note: except for adding the cubbies and some other modifications to extend the bottom sill, this was all installed by a previous owner and they're painted, so I'm not sure what type of wood it is. To the best of my knowledge, the utility brackets and being attached to the shelf on the short length are the only support used)
