I just bought a new home and the living room has a wood stove with a fan. It heats the 1st and 2nd floor great, however since heat doesn't sink, what do I do about the basement? I live in NE Mass and the winter has come (6" snow tomorrow!) and I'm worried about pipes freezing in my basement. Should I be worried at all or can I do something to ensure they don't?
Tell me more
There's two questions here.
Probably not. Provided you don't have a lot of the foundation wall exposed to the air outside, the basement will likely always remain above freezing due to ground temperature. Ensuring that you properly insulate the stud bays and the like will make that even less likely to freeze.
I'm not sure that you can short of there being perhaps some sort of duct-work system designed for wood stoves where you could force warm air into the basement. The alternative would be to move the wood stove. Put it in the basement allow it to heat from the lowest point. |
