Tell me more ×
I have an axe with a damaged handle that needs replacing, but I don't know how to do it. What tools and techniques should I use to get the job done?
There are different types of axes and axe handles - a pic would be helpful. – The Evil Greebo Oct 26 '11 at 9:44
up vote 16 down vote accepted
You'll have a couple choices when replacing the handle, you can either get a good Hickory replacement handle like this,
or a Fiberglass handle like this.
Comparing handle types is beyond the scope of this answer.
Either way the repair starts the same way, by removing the old axe head. This will likely be the most difficult part of the job, as the handle was installed to not come out. You may be able to drill out enough of the material, so the handle will easily slide out. You could also try removing the metal and wood wedges (reverse of install) to remove the head, but sometimes the wooden wedge is glued in so you may not be able to remove it. If the old handle was fiberglass, it may be easier to purchase a new axe. Removing the old epoxy can be difficult, and time consuming.
Once you have the old handle removed, the installation of the new one is slightly different depending on the handle you've chosen.
Installing a Hickory (wood) handle:
It's best to buy a replacement handle that includes everything you'll need to install it, which will likely come with a notch already cut in the top of the handle (so you won't have to cut this yourself). If you can only find a handle with a wooden wedge and no metal wedges, the metal wedges are available separately.
  • Start by sliding the handle into the axe head.
  • Next put the wooden wedge into the slot at the top of the handle.
  • Tap the wedge in with a hammer.
  • Cut, file, or sand off the excess wedge (it does not have to be perfectly flush).
  • Tap the metal wedges in perpendicular to the wood wedge.
  • Go chop some wood.
Installing a Fiberglass handle:
When purchasing a fiberglass handle, try to find one that includes the epoxy. If you can only find handles, the epoxy kits are available separately.
When installing a fiberglass handle, you'll have to make sure the hole in the axe head is clean. You can use sand paper, or a small round file to clean the hole before installation.
  • Start by wrapping the caulking cord (that came with the epoxy) around the handle where the bottom of the head will meet it.
  • Push the head onto the handle, making sure the caulking cord creates a good seal between the head and handle (or you'll get epoxy all over).
  • Mix up the epoxy, and pour it into the top of the ake head.
  • Store the axe vertically (top of axe up) so the epoxy does not leak out, for up to a week (follow directions on epoxy kit).
Great answer! +1 – Doresoom Oct 26 '11 at 13:53
Though it wasn't specifically asked in my question, from what you say it seems to be a good idea to use a wooden handle as the replacement in case it ever needs replacing again (a fibreglass one would be tough to remove). Nice answer - thanks very much! – Highly Irregular Oct 27 '11 at 4:19
... Except fiberglass handles are very tough and far more weather-resistant; not that I would recommend leaving your tools out in the elements, but if you did, I'd expect the fiberglass handle to last much longer. – KeithS Oct 31 '11 at 20:17
Standard guidance seems to be:
  • Remove old handle - drill, cut and bash the old one out
  • Make sure the new one is the right size to fit in the axe head, then cut a slit across it
  • Bash it into the head (lots of the process requires hitting and bashing)
  • Hammer a wooden wedge into the slit then file/sand down any excess sticking out above the head
  • Hammer one or two metal wedges across the wooden wedge
I've only done this once but it was good fun. Get the wedges in solidly to avoid the axe head flying off, though:-)
Do you mean metal staples in the last step? – ChrisF Oct 26 '11 at 11:10
The ones I got with my new handle were a combination of staple and wedge - sort of a wedge with a spike at each end. – Rory Alsop Oct 26 '11 at 11:45
