What are the types of tools that I would need to have access to in order to build something like a table from wood?
closed as not a real question by Tester101, BMitch, ChrisF Nov 17 '11 at 17:03
It's difficult to tell what is being asked here. This question is ambiguous, vague, incomplete, overly broad, or rhetorical and cannot be reasonably answered in its current form. For help clarifying this question so that it can be reopened, visit the help center.If this question can be reworded to fit the rules in the help center, please edit the question.
What type of table? How fancy/complex would you like the table to be? You could build a table by placing plywood on saw horses, in which case no tools are needed (aside from saw horses). – Tester101 Oct 21 '11 at 15:17
Was going to try to build a 4'x6' table with room for many people to sit around, storage areas for game pieces, built-in cupholders, etc. – GWLlosa Oct 21 '11 at 15:36
You should update your question with more detail, maybe a sketch of what you have in mind. Your level of carpentry skill might also help, as some techniques are more advanced than others. – Tester101 Oct 21 '11 at 15:40
If you have to ask what tools you need to build a table, I'm not sure this is a project you want to tackle. – DA01 Oct 21 '11 at 16:17
up vote 2 down vote accepted
It depends in no small part on how you wish to construct the table. For instance, if you wish to do a simple screw or nail construction, it's a different set of end tools than if you wanted to do dove-tail joints, or biscuit joints, or mortice and tenant joints...
The basics (screw construction)
  • Measuring tape
  • Pencils
  • A straight edge (usually part of a related tool)
  • A saw
  • A drill (for pre drilling screw holes)
  • A screwdriver or driver bit for your drill - for installing the screws
  • Several grits of sand paper from coarse (60 grit) to ultra fine (220 grit)
  • A sanding block (flat surface used to keep your sand paper flat)
