I am talking about those small and narrow screwdrivers with a thin handle. I can't get a tight enough grip on the handle to generate enough torque to remove a small screw. Do I have to use something else with it?
Tell me more
There are precision screwdrivers available that have larger handles, such as this one from Home Depot:
In general, you press down on the tip while you screw in or out: this helps to hold the screwdriver in the slots in the screw head and allows you to use more force to turn the screw. |
Use a pair of pliers to grab the screwdriver, and while applying downward force to the screwdriver (so it doesn't slip and strip your screws), carefully apply pressure using the pliers. |
