Tell me more ×
I just moved into an old flat which has old and weathered down sash windows which let a lot of cold air in. As Scotland does get very cold at times I would like to insulate them in a cheap and efficient way. If it lasts for only a winter that would be fine, longer would be better of course.
My windows look like this more or less:
just that i only have 4 glass tiles (2 in the upper sash and two in the lower).
1 Answer
The main source of heat loss is not through the glass but through the gaps in the window frame and where the sashes rattle.
There are various ways you can reduce the air flow though the window.
The cheapest would be to install some cling film secondary glazing. This one looks like it just tapes up over the windows to keep the draughts out. Other systems use heat to shrink the film to size.
You could hang some heavy curtains. Make sure that they reach all the way to the floor and are plenty wide enough so you can have maximum gathering. If you line them as well there'll be two layers of fabric between the window and the room.
Next up is something like this from 365 Plastics. It's sheets of perspex cut to size and fastened to the windows with magnetic strips. We have this and it works quite well. The main drawback is storing the sheets in the summer.
A less visible solution, which you might want to use in association with one of the above is to renovate the windows with something like one of these draught proofing kits (others are available!). With these you replace the staff and parting beads with the supplied parts that include brush pile that forms the actual draught-proofing.
Thanks for your reply! Unfortunately I don't have space to hang heavy curtains, as there is no curtain bar to attach them. But the cling film secondary glazing sounds promising, especially since I only have single glazing on those windows. So if I understand properly it's just a plastic sheet that is taped over the whole glass part of the window? Question would them be: how easy is it to remove again? (since I am only renting the flat over the winter) Also the frame and sash themselves are not connected very tightly thus letting some air in as well. Any cheap ideas how to insulate that? – Pitt Oct 19 '11 at 13:59
@Pitt I've not used the plastic film so don't know how easy it is to remove (sorry). Anything else I suggested would require your landlord to get involved. – ChrisF Oct 19 '11 at 14:10
Thanks for the tips though. I guess it depends on how easy the double sided tape is to remove from the frame. – Pitt Oct 19 '11 at 15:19
@Pit - you stick the film to the outer (fixed) frame, that way it also blocks the gaps around the moving parts. It's easy to get off with your fingernail or a knife if you are carefull – mgb Oct 20 '11 at 15:26
