Tell me more ×
One of our metal windows is missing a screen and I'd like to replace it. I don't have other windows of the same size so I can't easily copy the screen dimensions. How should I measure the window opening so that the new screen will install properly? The instructions that were included with my screen framing kit are insufficient and literally say "measure the opening".
Mr. Google suggested measuring the full length of the screen opening and subtracting 1/16". If I do that though, I would think that the screen would be too big to fit. Can I get some advise on where exactly I should measure?
What do you mean by "metal window"? Exactly what type of window is it? Casement? Double hung? Single Hung? Slider? – The Evil Greebo Oct 17 '11 at 15:52
@TheEvilGreebo It's a single pane window with metal frame. – Mike B Oct 17 '11 at 19:01
Do you mean a storm window mounted exterior to the main window? Can you post a pic of this window? – The Evil Greebo Oct 17 '11 at 19:04
Do you want to replace just the screen (do you have an existing frame for the screen you can use)? Or do you need a new frame and screen? – auujay Oct 18 '11 at 17:10
@auujay Both frame and screen. – Mike B Oct 19 '11 at 15:54
1 Answer
up vote 1 down vote accepted
Don't get to hung up on the exact size the piece of screen needs to be. simply measure the width and height of the frame and buy a piece of screen large enough. Normally it comes in standard widths and cut to length. Once you lay and stretch the screen over your frame, install the spline on one end, stretch, install sides and opposite end. An inexpensive spline roller comes in handy here. Use some sharp scissors, utility knife or shears and trim off the excess close to the spline. Done!
