Tell me more ×
Can my friends and I use a torch gas cutter to cut into the roof, and dismantle everything by sections? I imagine there will be some concrete layering underneath and such.
closed as not a real question by Tester101, ChrisF Nov 17 '11 at 21:27
It's difficult to tell what is being asked here. This question is ambiguous, vague, incomplete, overly broad, or rhetorical and cannot be reasonably answered in its current form. For help clarifying this question so that it can be reopened, see the FAQ.
1 Answer
Very small pictures, but if I'm seeing them correctly, that's a standard shingle roof which means it'll be over wood sheathing.
So no, using a flame cutter would be a substantially bad idea. Unless you want the building to burn down, that is.
