Tell me more ×
I've heard that burning pine in your fireplace can cause creosote to build up in the chimney. If I get my chimney swept at the beginning of the season should i be safe to burn pine for the rest of the winter? Are there any other precautions I should take before/while doing this?
read the comments at the bottom of this: ehow.com/how_5751541_burn-pine-logs-fireplace.html – JoeHobbit Oct 2 '11 at 2:58
1 Answer
up vote 5 down vote accepted
There is no hard and fast rule. A few fires a season may be OK, a daily fire that is not very hot may not be. Creosote builds up from vapors condensing on the interior surface of the chimney, so the amount of buildup will depend on how hot the fire is, chimney construction, and possibly even what time of year the wood was cut (there is more sap in the wood in spring, for example).
I would definitely discuss this with your chimney sweep; if they are knowledgeable, they can help assess the chimney construction and probably give you some tips on how to minimize creosote buildup with your particular configuration.
Keep in mind that chimney fires can be extremely dangerous to your house, so it would pay to be conservative.
