Tell me more ×
I've read that the best way to "antique" a mirror is to use hydrochloric/muriatic acid to burn away some of the metallic backing. According to different sources it can be found easily at hardware stores, but I've had no luck near me and employees look at me like I'm crazy. What products use this strong an acid? I tried CLR, but it wasn't really strong enough. Any ideas?
You need to find a better hardware store. FWIW, you can order it online:
http://www.amazon.com/s?field-keywords=muratic%20acid
Yeah, apparently I do. – unusualhabit Sep 21 '11 at 14:32
A lot of times you'll find it in the masonry section of your hardware store. It is used a lot for cleaning brick after it is set.
Hydrochloric acid is the key component in swimming pool acidifying products (pH Minus). These products usually contain a buffer, which may make them less useful for your project. But, you can also by the stuff "straight": Crown Muriatic Acid - 1 Gallon at Lowe's.
Muriatic Acid is also commonly sold for cleaning heavily stained toilets.
