I have been doing a lot of decorative concrete around my house, and I have yet to find a masking tape or caulking or anything that can hold the acid stain where I want it. I finally found something that I think will work, it's a gel that makes the stain thicker and keeps it in place. This way you can just paint it where you want it. The problem is that it is not sold in the colors that I want. So, does anyone know what I could add to an acid stain to make it thicker like that?
up vote 4 down vote accepted
+100
Quick Google search turns up Modello Gel-lo
Modello Gel-lo is a thickening agent for liquid coloring mediums such as acid and water-based stains for concrete. The addition of Modello Gel-lo allows for more controlled color application and helps to reduce "wicking" of the stains under the edges of the Modello patterns.
And Stain Mule™.
Stain Mule will thicken both acid stains and water based colorants. When color placement control is necessary, the Mule is your product.
I'd go with the first one, that way if somebody asks "What's that stuff you're using". you could break into song "They call it Modello Gel-lo". – Tester101 Sep 16 '11 at 17:05
You know, I had found those before and that is how I knew that it exists. Maybe I should have thought of that before offering a bounty. But the funny thing is that you cannot buy either of those products. That is why I was looking for something that I could actually get. Oh well. Thank you. – Tatton Chantry Sep 16 '11 at 18:20
Actually, just on a lark I called the contact number for the Stain Mule, and the lady let me order it direct. Thanks a ton for making me look at that again @Tester101 – Tatton Chantry Sep 16 '11 at 18:57
