I am in the process of repainting my deck. I'd like to have a protective layer (like clearcoat on a car) that will allow easier cleanup, and would help to pretect the new paint. Is polyurethane appropriate for the job?
Tell me more
What you're looking for is Spar Urethane. Polyurethane is not good for outdoor use. Spar urethane will hold up the UV rays better. |
I don't ever like film finishes (whether paint or poly or varnishes) for horizontal exterior surfaces. Water and sun will win. Then you must remove chipped paint/finish before renewing The use of penetrating transparent or semi-opaque exterior rated stains, will breath and last longer. Overcoats can be made after washing and drying the surface. |
There are additives you can add to a floor coating which reduce slipperiness, such as polypropylene beads. |
