I noticed my house wasn't getting under 75°F this weekend when I had the thermostat set for 70°F. Since I'd done a lot of drywall sanding inside recently, my first idea was to replace the filthy air filter.
- My first indication that the air filter wasn't the root cause was when the return didn't have enough suction to hold the air filter in place while I was replacing it.
- I went outside to look at the compressor unit and discovered the exposed portion of the coolant line running into the house was frozen, but the fan was still running.
- The evaporator drain line still had a steady stream of water coming out of it.
- After turning everything off and waiting for the line to thaw, I turned the thermostat back on. Cooler air came out of the vents, but it didn't seem to be blowing with much force, and it wasn't as cool as it should be.
- I went back outside and discovered the coolant line was already frosting up again. At this point it was already dark, so I turned everything back off and slept with the ceiling fan on. :/
Other random notes that may or may not play a factor:
- The AC unit had been sitting idle the past 3 days since we had nice weather in the mid-70's last week.
- I mowed the lawn next to the condenser unit the day I noticed it stopped working. However, I was bagging the grass clippings, so nothing should have been blown into the unit.
Any ideas on the root cause of the icing and lower air flow? I wouldn't think the two would be connected normally. Is it something as simple as low coolant levels? I plan on going to look more closely at it after work today. What are some other things I should pay attention to?
UPDATE: I checked the system after work today and decided to give it one more chance after I couldn't find anything wrong with it. After a few hours, it had brought the inside temperature down from 80°F to 75°F. I periodically checked the coolant line for freezing, but it never got much colder than 60ish degrees.
I think the root cause was the air filter, and that I didn't allow enough time for the line to thaw last night.
UPDATE 2: Maybe I drew conclusions too soon - I just checked the coolant line and discovered frost on it again. The inside temperature was at 72°F while the outside was at 66°F. I think pumping warm air to a cooler outside temperature may have contributed to the icing, but I'm not completely sure. (And if you think I'm crazy for running the AC when I could just open the window, you'd think twice too if you saw how many bugs swarm my porch light and windows every night. Dozens of them somehow find their way past the screens if I open the windows.) I plan on running it again tomorrow during the day and monitoring the coolant line temperature every few hours. If it freezes up again, I think I'm going to cave and call a repair guy.
