Tell me more ×
My dog is an escape artist and managed to get out of her crate today. She then tried to chew her way through my bedroom door to escape confinement. Though unsuccessful, she did damage a significant part of the door. I live in a rented apartment and I would like to know if there is a way to fix this short of replacing the door. If not, is there a way to replace the door that would match this door (and the others in the apartment)? I would like to get my security deposit back if possible!
I will try to post a picture but it's proving challenging from my phone at the moment.
You'll only be able to add a link to a picture until you gain some reputation (see the faq). If you can't provide a photo at least describe the door: hollow core vs. solid; single panel vs. 4-panel or 6-panel or...; painted vs. natural wood; and so on. – Niall C. Sep 7 '11 at 0:02
If it's a cheap hollow-core door, probably easiest to buy a new one ($50 or so). – DA01 Sep 7 '11 at 0:28
@DA01: I agree that it may be cheaper to replace, but the knowledge of how to install it, not to mention caulk and paint, makes it a non-trivial job. When you factor in tools, the landlord may be able to do it cheaper. Best to ask first. – BMitch Sep 7 '11 at 2:41
1 Answer
If its hollow then there no way to fix it unless its just on the surface. If its painted than you can just apply some wood filler and sand smooth and repaint the area. It will look as good as new.
