Sign up ×
I've just moved into a "basement-ish" apartment; the actual ground level is about at my waist. It's a bit mustier than I'd hoped, and not as cool as I'd like during these closing days of Summer. I'm looking to pick up a small dehumidifier, and a small portable air conditioner, one to handle dampness in general; and the other to keep me cool.
In looking at my portable AC options, I see that there are a bunch of them that also function as dehumidifiers, on their own. Does anyone know if they're decent and efficient at this task? Should I stick to purchasing separate units, or can I get by with a two-in-one?
up vote 2 down vote accepted
Actually, an AC unit is a dehumidifier by default -- so the two in one things are just advertising something that an AC unit already does.
Sure, but in the winter, it'll only be running the fan; it will be too cold for the thermostat to trigger the compressor/condenser. – Eric B Sep 6 '11 at 16:07
The compressor has to run in order to dehumidify. A dehumidifier is simply an air conditioner that doesn't keep the cold air separate from the hot air. – Loren Pechtel Sep 8 '11 at 1:34
It is very unlikely that a two-in-one will be as flexible as two separate units. Most ACs have a fixed relationship between the level of de-humidification and the level of cooling. There will likely be times when you want just de-humidification without cooling.
So if you can afford it, you will be more comfortable with two units.
