Take the 2-minute tour ×
I need to cut a few bits of 6” plastic duct, is there an easy way to do this?
(Trying to get the ends squared using a freehand hacksaw does not look easy.)
Do you have a mitre saw? or a mitre box? –  Joe Sep 1 '11 at 19:08
@Joe, not yet but I may buy tools for this job –  Walker Sep 2 '11 at 8:25
If you're going to use a hand saw, you need a mitre box really. It's way too hard to cut square by hand, because if you start at even a bit of an angle, the saw is going to want to follow that cut.
  • If you have a mitre saw that is big enough, that's definitely the easiest.
  • A table saw may work in a pinch, if you use the sliding guide rail.
  • Make a couple marks using a measuring tape, then draw a line between them. Using a square is probably easy, or using a chalk line or piece of string can work too. You should then be able to use a jigsaw to follow the line and make a pretty even cut.
up vote 0 down vote accepted
I used a rubber band that I put round the duct; once I had the band in place I draw a line round the duct using the band as a guild. Then I used a hacksaw.
The fittings give an overlap of about 3cm, so the cut does not have to be spot on.
I also got some duct that would fit tightly inside the main duct, using a bit of this and two bits of the normal duct, I make sections that could be adjusted to the correct size in place.
