Tell me more ×
What should be considered when boarding up windows for a storm (or for that manner, during construction, etc.)? What thickness plywood is required? Should it be sized to the size of the sash and fastened inside the frame, or should the framing be covered as well?
1 Answer
up vote 1 down vote accepted
First measure across the window, door, vent from the inside of the exterior trim to the outside of the exterior trim on the other side. Do this vertically and horizontally. Then add 6-8 inches to BOTH measurements, this is the size of plywood you need. You add length and width because you don't want the plywood pushing on the glass.
The thickness of the plywood is a personal choice, I would use 3/8 or 1/2 inch, but remember 1/2 is more expensive and weights more. I have never had problems with 3/8.
When you attach it to your wall, you can do things quickly or carefully. This depends upon what the exterior of your house is, how much time you have, and how often you see yourself doing this in the future. You could just screw the plywood to the wall with a long screw every 12-14 inches. OR you drill holes into the boards, hold it to the wall, mark the hole locations, then drill into your house and use a tap and die to make a more permanent screw hole.
The former option is preferred if you don't see yourself protecting your home that often. But if you live in tornado alley, I would definitely upgrade to 1/2 inch and use a tap and die for strength and convenience.
Thanks. Elected not to board up this time, as Irene was weakening as it approached us, but may use this in the future. – TomG Aug 31 '11 at 3:54
