Tell me more ×
http://www.housekeepinghere.com/weekly/baking-soda-carpets/ says that I should keep the carpet dry, while http://www.repair-home.com/flooring/carpet/carpet-cleaning-solutions.html says that I should spray the area with water.
1 Answer
Baking soda needs to be in contact with the odors to work. If the baking soda is wet, it will not really work at all because the water will be blocking the odors from getting near the surface of the baking soda. I also suspect it would be a real mess to clean up.
In the past I've tried baking soda on carpets (dry!) and found it to be a waste of time. A professional steam cleaning is probably the most effective solution.
Oh wow, I see. =/ Well, could I wait for the water to evaporate then? – InquilineKea Aug 25 '11 at 7:41
Instead of a fine powder which is easy to vacuum you'll end up with clumpy baking soda that might even be stuck to the surface you sprayed it on. Keep it dry. – Stephen Aug 25 '11 at 13:03
