Tell me more ×
I may have a renter moving into a condo in a couple of weeks. I already ordered a full window replacement for the bedroom. Since a pane of glass (3' x 4') is missing, I'm thinking to put on a plastic or glass like material just for a couple of weeks instead of wasting $150 for a real pane of glass and throw it away after two weeks. Of course this will happen with the tenant's consent.
Is there material like that? Where can I buy it?
up vote 3 down vote accepted
The most common temporary fix I see is a piece of plywood. This is one of the cheapest, but is not the most aesthetic solution.
If you go to a company that sells glass and mirror you will find much better prices opposed to something that you would purchase at a hardware store or online.
Glass is much cheaper than plastic. You can go with a piece of DS (double strength 1/8") glass as a temporary solution as long as it is not in a location that is required to be safety glass according to building code.
You are right, I talked to a glass shop and they offered if I take the window frame to their shop, the would put a pane of glass on it for $25, labor included. – grokus Sep 10 '11 at 1:22
You can buy big sheets of plexi at big-box hardware stores, or online cut to size. A simple websearch for "plexiglass sheet" turned up a large number of wholesalers.
However, the cost may surprise you; a 36" x 48" x 1/4" sheet was $100 at the random place I checked.
Still, afterward you'll have a huge piece of very durable plexiglass that you could use for something else.
Along those lines...If the window isn't larger than a poster, you can get a $10 poster frame from Target and use the plastic that's in that. – DA01 Aug 22 '11 at 21:35
@DA01, thanks for your suggestion. – grokus Aug 22 '11 at 23:52
