I'm set to buy a bunch of IKEA furniture, which is notoriously all particle board. (Ah, particle board.) I'd like to strengthen some of the beams of the HOPEN bed with L-brackets from the big-box hardware store of choice.
My question is this: since adding the L-brackets will mean screws, do I need to pre-drill holes into the wood to avoid splitting the particle board? Is there a way to prep these holes without a hand-held power drill? Can I drill the L-brackets in without pre-drilling at all but with great care?
While IKEA furniture is certainly cheap and there's a proliferation of particle board, they are also usually engineered quite well. I doubt you need to add any of your own re-enforcing hardware to it. – DA01 Aug 22 '11 at 21:38
My friend has had the runners along the sides of the bed snap on her in the past. As I am not one of those ladyfolk who weights 110 lbs soaking wet, I figured a little insurance couldn't hurt ;) – Aarthi Aug 23 '11 at 14:04
Yes drill holes- if you just jam it in there it will split the board. Dont drill exact sizes just about 1 or 2 mm smaller. Otherwise you wont have compression and the screw will fall out over time. – ppumkin Aug 23 '11 at 15:55
Note: There are specialized fasteners for use with particle board. (Conformat screws, if I remember correctly.) Installed properly, these will hold better in this material than normal screws would. Used these when building a melamine storage/closet wall in my last apartment. – keshlam Jul 24 '15 at 23:44
up vote 6 down vote accepted
To answer your question: it depends. The larger the screw, the more likely you'll need to pre-drill. If you're installing the screw near the edge, or if the screw is larger than maybe 1/8" wide on the solid part, then I'd pre-drill. To pre-drill, make the hole almost as large as the solid part of the screw (not the threads themselves, they need to have something to bite into). Also, make the hole as deep as the screw minus the size of the bracket. Use some tape on the drill bit to see when to stop.
That said, for your bed, looking at the plans, I think you'll get the most added stability by adding a short piece of 2x2 vertically as a center brace under the metal bar. Check the hardware isle of your HI store to see if you can find an adjustable foot to put on this board, and then attach it via a few screws to the center beam. This is actually a quick way to detect some lower quality beds that use wooden slats from side to side. If the slats have a center brace going to the floor, it's a lower quality bed.
Edit: For clarity, just imagine a table with a 5th leg right in the middle. You have a long span from the headboard to the foot of the bed which will benefit from an extra support directly in the middle. The adjustable legs I'm thinking of screw into the wood leg of a piece of furniture and look something like this (this is a cutaway view, you simply install it into a hole you drill into the bottom of the leg):
adjustable table leg
I'm not sure I understand your second paragraph; could you go into more detail? – Aarthi Aug 23 '11 at 14:06
@Aarthi, hopefully that edit helps. – BMitch Aug 23 '11 at 14:45
As BMitch has said, it depends on the size of the screw, how near you are to the edge, etc.
It also depends on how hard/soft the wood is. The harder the wood, the more you should make a pilot hole near to the diameter of the inner threads. I'd say in hard wood, you should consider using a pilot hole when the inner threads of the screw are 1/8th of an inch, and definitely use one if the inner threads are 3/16ths of an inch.
Softer wood, on the other hand, will be more willing to accommodate a screw significantly larger than the pilot, and using a smaller pilot hole is actually desirable, as it creates more pressure against the screw, and that means higher pull-out strength.
Obviously particle board should be considered a soft wood. If, for example, you use a screw with inner threads that are roughly 1/8th of an inch, then I wouldn't normally use a pilot hole... but I think you probably should use a 1/16th pilot in your case since you are most likely working with thin pieces of wood, and you don't want to risk having the excessive pressure creating visible deformities.
one word. . . GLUE!
Particle board crumbles and nails, screws and staples are almost ridiculous. I just had a particle board kitchen cabinet come falling down because there was nothing holding it up on the wall (with all the heavy china and everything) but a couple of lousy staples. The rest of the cabinet is held together with simple joints (not as angular as dovetails) and GLUE. The glued part is doing quite fine thank you. Why they didn't use glue on the supporting edge I will never know. (The cabinet has been glued now and is going back up!)
To have furniture that is re-assemble-able there must be a female screw receptor sunk into the particle board--preferably glued in. If these fall out, Gorilla glue foams while drying and is really wonderful, while regular carpenters glue is great if you are simply gluing particle board to particle board (watch for plastic coatings).
Also for steamy places, such as cook stoves and bathrooms, particle board and hard board, especially that must support weight, should be painted/finished to prevent the absorption of moisture which will cause it to warp and disassemble.
While this provides an alternative way to bond the materials, it does not answer the actual question and might be more appropriate as a comment. – Steven May 14 '13 at 18:53
Virtually everything from Ikea that's made of particleboard has no glue. You just need to use the right kind of screws & bolts & interesting fasteners that Ikea has virtually mastered. If you're buying furniture only held together with staples then there's your problem – Xen2050 Jan 9 at 19:41
