I need to cut 2x2 ft square pieces from a sheet of memory foam. Not sure what tool is best for this. Any ideas? In the future I'd like to cut circles and eventually sculpt irregular shapes, I don't know what tool can be used for this sort of job.
For thicker pieces you might find you get better results by compressing the foam before cutting it. You could make a simple straight-line clamp out of a couple of 2x4s linked with a door hinge -- just put your foam in between, clamp the open end shut with a C-clamp, and use one edge of the wood as a guide for your cut. For your curved cuts it might make more sense to make a plywood die to match the final shape and press it down by hand or with something heavy before cutting around it. |
I used a sharp razor knife on my memory foam. You can make a line and just make long cuts. Do not try to cut through it all at once. Start by making your first cut deep enough that you can follow it through and make a straight cut. Just keep cutting down your line until you are through. Take your time and be careful and you will have a clean cut. Don't use a saw or hot knife you will just ruin your topper. A razor knife is your best tool for this. |
If this were styrofoam, I'd recommend a hot knife (basically a wire stretched taut on a frame similar to a jigsaw, and electrified to heat it). However, visco-elastic foam will behave differently and you probably don't want to be breathing in the fumes produces by melting it. In this white paper from the Polyurethane Foam Association regarding visco-elastic ("memory") foam, the PFA states that most conventional tools including saws can be used to cut VEF. However, care must be taken to go slowly and not deform the foam too much with the cutting action, because the slower recovery of VEF to its original shape will cause defects in the kerf line and possibly cause the saw to bind more easily. |
An electric fillet knife does great at cutting this stuff. Seriously. Give it a try if you have one. |
If you don't have an electric carving knife, which is the best tool, use a serrated bread knife. Same action on both. |
