Tell me more ×
I am planning on using the flexible faucet feed lines for a project I am working on. (they have a metallic outside and I suspect vinyl or plastic interior)
The temperature of the fluid that I will be running though it (maple sap) will be around 100F to 180F - but I don't know yet. I am building a preheater out of copper tube and need a way to connect two parts that are fixed but must be able to disconnect
I don't want the part to fail or break down and I do not want the material to leach into the fluid.
Are these feed lines acceptable for temps to 180F?
Is there another alternative that allows flexibility and easy connect/disconnect on one side of the part?
I think you are reaching an upper limit with 180F. I think those pipes are rated to 215F. but to be honest i am not sure if its a good idea to use those for food stuffs. – ppumkin Aug 15 '11 at 10:05
OK, thanks. I made a preheater for maple sap (for making maple syrup) Copper pipe sits in a hood over a pan of boiling sap. Steam rises, condenses on the copper and transfers heat. The sap runs through the pipe and I need flexible connections on two parts - also ones that would be able to be taken off and on with ease. Thanks for the comment. – Tim Aug 15 '11 at 14:12
1 Answer
The tubing should have a stamp on the side that says what temperature range it can handle.
