I have a tiled shower in an older house, and it's been a struggle to keep the grout clear of mold and mildew. I'm planning on installing a bathroom vent to prevent future buildup, but in the meantime, what is a good approach for a good, deep clean?
Was there any evidence of mold in the wall itself when you did the tile work? – BMitch Aug 10 '11 at 2:31
Does anyone know if there are steps to be taken after a cleaning to prevent recurrence of mold? Would it be appropriate to apply a grout sealer or something? – Shimon Rura Aug 10 '11 at 15:10
@BMitch the tile is original (from 1960). – James Sulak Aug 10 '11 at 15:29
@Shimon Perhaps pose the post-cleaning question as a separate question. – Stephen Aug 10 '11 at 15:40
up vote 10 down vote accepted
To remove surface mold I use a 4:1 mixture of water:bleach. Spray on liberally and allow to sit for about 15 minutes. Rinse with water and wipe clean.
If you need to use a brush to scrape off heavy deposits, I recommend brushing away from your face or preferably wear an appropriate mask and goggles. The mold spores are probably more dangerous than the bleach at that point, but neither one is fun.
Commercial cleaners such as Tilex tend to do a reasonably good job as well.
Whichever way you go, make sure that you give yourself adequate ventilation as the fumes may be quite strong.
As you've already noted that you need to take remedial action to prevent future growth, I'll just echo BMitch's comment that you should investigate if the mold has spread into the walls as hidden growth can be a future problem.
If you're using a brush, you're splashing bleach around. Definitely wear goggles! – Alger Aug 11 '11 at 2:41
If there's mold behind the tile, which is likely given the age of the house, then cleaning will only push it back into the grout and delay the problem until the grout decays. Your best option over time is to demolish the old shower, put in a proper waterproofing membrane that's designed to be tiled over, (e.g. kerdi), and re-tile.
