I went to replace a ceiling fan on a cathedral ceiling in my house yesterday, and upon removing the old fan I noticed that there is no electrical box where the fan was mounted. The fan was hung from a ceiling joist with romex running to the location, and the wiring was done underneath the fan's mounting bracket and canopy cover. It looks like the replacement fan would be wired in the same area, so does it matter if there's no electrical box under the drywall? If so, why?
Can you post a photo? – Tester101 Jan 15 at 17:53
I wish I had taken one when I had the ladder out. It's about 14 feet up so it would take a while to get the ladder setup again. Anyways, now that the old fan has been removed it's just a hole in the ceiling drywall right alongside a ceiling joist with romex poking out of the hole. I can see insulation on the other side and there doesn't appear to be a box. – Jonathan Jan 15 at 17:54
So you're saying the fan bracket was just screwed directly into the ceiling joist? Is the house out in the country where city codes and inspectors wouldn't apply? – JPhi1618 Jan 15 at 18:00
@Tester101 Added a picture. You can see some of the holes in the drywall running parallel to the joist - 4 screws held the fan bracket. – Jonathan Jan 15 at 18:08
up vote 10 down vote accepted
Electrical boxes serve several functions. They protect wiring where insulation has been removed. They prevent inadvertent contact with exposed components. They contain sparks when the worst occurs. And they provide standard mounting points for fixtures.
I'd be inclined to "code things up" with a wraparound box like so:
Nonmetallic ceiling joist box for ceiling fans. 4'' diameter x 2 1/8'' deep, 12.0 cu. in. 4 clamps, 2 1/2'' knockouts. Maximum fixture weight is 150 lb., maximum fan weight is 70 lb. Exceeds National Electrical code requirements. Recommended for earthquake areas.
That looks promising. Just to make sure I understand how this would work - so the screw in the middle mounts the box to the joist and the vertical slots are where the fixture would mount to the box (and presumably, into the joist as well)? Then I'm guessing the wiring would need to be packed into the openings on the left or right side? – Jonathan Jan 15 at 18:18
Correct, though your fan shroud probably leaves additional space, so you may be able to lay wires above (below) the joist ridge. Ideally the connectors will get poked into the box itself. – isherwood Jan 15 at 18:20
Good info, thanks. I'm hoping that the size of the box along with the existing hole won't require any drywall patching, but this seems like a good approach. – Jonathan Jan 15 at 18:25
This is exactly what I'd do. +1 – Comintern Jan 15 at 18:25
There are UL listed boxes, like these, sold at most hardware stores. Specifically for ceiling fans. – TFK Jan 15 at 18:33
As far as code goes, the wiring must be done in a box and that box must be rated to support the weight of the fan. It's not code compliant if it were to be inspected.
But on to what this means to you, since most likely an inspector wouldn't check it.. You could say that the joist will support the fan and that the wires are secured, but if any were to come loose it could cause a fire since there isn't a box to protect it. That's about it.
I have this exact thing done under one of my ceiling fans in my new house and it seems to be a common issue. I've not gotten around to fixing it and it most likely won't ever cause a fire, but it would still be safer to pay a couple dollars and prevent it in any case.
Thanks for this info. – Jonathan Jan 15 at 18:25
And in case you think the wires will not come loose, remember that a ceiling fan, by design, contains moving parts. They cause vibrations which, over time, may cause a wire to come loose out of a wire nut. I would definitely want a box to contain any sparks, and if made of metal, force a short to ground which will trip a breaker. – Snowman Jan 15 at 19:55
@Snowman What of the sort of boxes that isherwood pointed out above being made of plastic. What happens in that case? – Jonathan Jan 15 at 20:18
@JoshStone The metal would prevent a ground fault of the wires themselves by allowing the fault and causing the breaker to trip. Plastic doesn't conduct the electricity through it and so if a wire were to come loose, it wouldn't trip a breaker, but it wouldn't burn anything other than the box as it's still protected and your device wouldn't work. --- One way allows the fault but stops it, the other way just blocks out the possibility of a fault. – TFK Jan 15 at 20:21
