Tell me more ×
I have an old whirlpool top loading LA8800 (Maytag rebranding?) washer that leaks from the bottom.. is this usually a simple (and cheap) gasket type repair, or would now be a good time to get a more energy (water?) efficient front loading type?
Also, anyone know what the capacity is of my Whirlpool LA8800? I can't seem to find any specs on it, my current washer!)
Is the leak from the bottom of the drum, or up in the plumbing (pump, etc.)? If it's leaking from the drum, then it's definitely time to replace. Otherwise it can be repaired. – Karl Katzke Aug 8 '11 at 4:00
It depends on what and how exactly leaks. It may be for example the drain filter cover loosened - then you just clean the filter, tighten the cover and continue using your appliance. – sharptooth Aug 8 '11 at 5:30
@Karl, I think that deserves to be an answer. – BMitch Aug 9 '11 at 11:51
I'd say replace it no matter what, unless you're living alone or low on funds.
For a typical household, a front-loading washer will save $10-15 each month, so a new washer would pay itself off in 5-8 years.
The August Issue of Consumer Reports had an article on this. I don't think they publish the full article on their non-subscriber site but they do have some information posted:
http://www.consumerreports.org/cro/magazine-archive/2011/august/shopping/repair-or-replace-it/overview/index.htm
