I'm living in an old apartment, circa 1945. The walls seem to be made of an incredibly hard stone or concrete. Any recommendations on the right drill bit type to use? My standard set doesn't even make a dent.
You need a commercial mortar drill with special bits. Those large and heavy ones guys with big muscles use - but trust me - threes no better way to go through stone! You will need to rent one - or call a specialist. – ppumkin Aug 5 '11 at 7:57
For drilling stone or concrete you'll want to use a good quality masonry bit, and a good rotary hammer drill.
As Shirlock points out quality is important here, so you don't want to skimp on the tools when drilling stone or concrete. You'll want to look for a carbide tipped masonry bit, as these tend to last a bit longer than the typical masonry bit. You'll also want to make sure the bit is rated to be used in a hammer drill, since a standard bit can easily be destroyed by the hammer action of the drill (causing personal/property damage and/or death).
If you're doing a small job and don't want to spend the money on expensive tools, you should be able to rent what you need from a local home center (Home Depot, Lowes).
A hammer drill is necessary when drilling stone or concrete, since grinding away the material with a standard drill would take far too long. A hammer drill works similar to a normal drill, but with an added mechanism that "hammers" the bit while also spinning it. The idea is that the hammer action will break up material at the bits tip, then the bit will grind up the loose material and carry it away along it's threads (clearing the hole).
To reduce heat on the bit you'll want to drill at a slower speed, and pull the bit out of the hole from time to time to clear the debris. Remember the hammer action can be brutal on the bit, so you'll want to use a quality bit and keep it cool to reduce the possibility of shattering it.
And for the love of god, never use a regular duty bit not designed specifically for hammer drills :) – Stephen Aug 4 '11 at 12:53
Thanks @Stephen. edited that info in. – Tester101 Aug 4 '11 at 12:59
If it is an interior wall, it is made from plaster on top of wood slats. For stone drilling, get what is called a tap-con drill bit. You are also going to want to use a hammer drill to make your holes. If it is stone, this bit will also work on stone or concrete like an exterior wall. Be sure to use a hammer drill.
Tap-con is a brand name for a class of bits known as masonry bits. There are wide differences in quality of these type bits, so don't be deceived by bargain brands, they will not work well or last for more than one or two minutes. If you need to drill several holes, get a good grade of bit and a good hammer drill. – shirlock homes Aug 4 '11 at 11:25
I personally prefer the Bosch "Blue Granite" and Bosch hammer drills. I've been let down by Hitachi hammer drills a few times, but the Bosch ones have always held up to the worst I can put out. – Karl Katzke Aug 4 '11 at 12:50
I have always liked Bosch tools. Porter Cable makes a nice hammer drill. I have always been a fan on the Tap-con masonary bit. That is why I said Tap-con because like Mr. Homes said, Don't be deceived by bargin prices. – lazoDev Aug 4 '11 at 14:18
protected by Community Sep 25 '15 at 20:18
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
