I had a pool installed a few years ago and the builder threw in a narrow concrete patio around it. See fuzzy picture below (sorry about that. Google earth must be a little tipsy tonight).
So now that I've paid off the pool, I'm thinking of putting down a flagstone patio, but the trick is that I want to extend it beyond the paltry concrete patio that already exists (dotted square around pool).
I assume it will be a pretty easy job to lay down the stone on top of a nice level concrete patio, but I am a little concerned about how to make the transition between the concrete part and the grass part.
(1) Is this even advisable, or should I just extend the concrete out to the entire area I want for the patio before laying stone (adding considerable cost)?
(2) Assuming I don't extend the concrete, what should I do when the stone transitions from the concrete subsurface to the dirt? I'm nervous that cracks will occur over time, and I'd like to do whatever I can to avoid that.
Pool Photo
did the pics come from a brownie on the space station? lololol – shirlock homes Aug 1 '11 at 22:05
Google Earth just doesn't have very good resolution at my location. That's all. – JohnFx Aug 2 '11 at 4:16
up vote 2 down vote accepted
Rolls-Royce job (Money no object): Extend the concrete slab out to the area you wish to pave or remove the existing slab and start allover again.
Good enough job (and what most paving pro's would do, at least the ones I know back in the UK): Excavate 6 to 8 inches (150 to 200mm) from the area you want to extend into. Back fill that area with sub-base (crushed rock) material. Back fill in 2 to 3 inch (50 to 75mm) layers, each layer should be "properly" compacted. This will give you a sub-base that is "nearly" as good/stable as the existing concrete slab.
  • Something to consider, regardless of chosen method, how is the paving area going to drain? Do you need to put in some sort of drainage system , thus preventing the surrounding softscape from flooding due to the new hardscape?
you can dig a foundation square where your dotted line is. atleast 15CM wide and 10cm foundation. You dont need to put a concrete slab on the whole thing. The trick is to cemeent the last slabs to the foundation. at an angle so that the grass/ground go. Like inside the blue lines.
This is not a brilliant autocad picture but it illustrates how to end your tiles. The red is cement/adhesive to the foundation. The length of the foundation should be atleast 1 tile flat. The poles in the ground are optional. If you have clayish ground you should use those and about 1 metre long. If you have topsoilish sand that does not tend to move due to moisture then dont worry about it. The squigly line is the natural grass/ground level and the straight brown area is hard/compacted not dug ground. Obvoisly the picture is not brilliant but you need sand under your tiles that i missed out. where on the concrete the adhevsive/cement will make up the height for the sand layer!
I hope this makes sense - I have done many paved areas like this and its a great long lasting solution.
