When I turned the valve off, it was as if it made a small click, as if it had reached a locking position.
Now I can't turn it on again.
I have one other just like this one, and that one can I turn on and off without problems.
Are there some trick to know in order to turn on a valve this this?
Picture of the valve I can't turn on again
@Niall C: Do you pull out at the same time? – Louise Jul 31 '11 at 16:09
@Niall C: You are a life saver. It worked =) It was as if the force had to come in a specific angle in order to it to turn. If you copy/paste your answer then I will accept it. Thanks a lot. – Louise Jul 31 '11 at 16:59
Consider switching to a ball lever valve if this remains a problem. – Hemm Oct 25 '11 at 19:45
up vote 4 down vote accepted
I have one that does the same thing; it just needs a little more twisting force to get it past that "locked" position. I've always been able to do it by hand, no tools required.
