Sign up ×
A bit embarrassed asking this, but... I'm trying to replace a leaking valve off my faucet assembly, but am unable to unscrew the faucet cap. Here is the faucet assembly - Taboret® widespread lavatory faucet - K-8211-4
up vote 5 down vote accepted
When you go to product site check out the "for owners" tab and open the second installation and care guide. On page 2, it shows the handle itself unscrewing so you can replace the red or blue color rings. Start opening it up there and see if you can work your way down to screw 55431 which is holding down the rest of the faucet to the valve.
faucet assembly
Upper handle assembly
Upper Handle Assembly
Lower handle assembly
Great! Thanks for taking the time out with the schematics. – rs79 Jul 28 '11 at 12:54
The schematics credit goes to @Tester101. Wish I could give you a +1 for that. – BMitch Jul 28 '11 at 14:08
Just thought it would be easier if the info was all in one place. And if the documents are ever moved or changed, the information still lives on here. – Tester101 Jul 28 '11 at 15:30
