A dishwasher is an appliance that holds dirty dishes and uses water jets to clean them up for use again. Use with [electrical] for wiring one up (these are almost always directly wired). Use with [plumbing] for connecting the water lines, and [drain] for connecting the drain lines.
There is no tag wiki for this tag … yet!
Tag wikis help introduce newcomers to the tag. They contain an overview of the topic defined by the tag, along with guidelines on its usage.
All registered users may propose new tag wikis.
(Note that if you have less than 20000 reputation, your tag wiki will be peer reviewed before it is published.)
