Tell me more ×
Today I noticed that the gasket seal surrounding the refrigerator door has a bit of a gap along the lower quarter of the door. The photo below shows my refrigerator door - notice how the white gasket is flush with the refrigerator from the top down to about six inches below the bottom of the door handle, but then there is a gap that starts to grow and runs down to the end of the door.
Gap in the refrigerator door insulation.
How would I go about fixing this gap? Do I need to buy a new strip of the door gasket and replace the existing one?
1 Answer
up vote 2 down vote accepted
Measure the space between the door and refrigerator on all sides/corners to see if something is out of alignment. And see if your hinges have an adjustment. It may be that the top right hinge is pushed too far towards the refrigerator.
I don't think that's the problem. With the door open the insulation is clearly "squished" where the gap is. It does not extend as far out as the insulation above. – Scott Mitchell Jul 24 '11 at 15:34
In that case, you'll likely have to replace the entire gasket. Here are some sample instructions that will put you on the right path, but review the instructions that come with the replacement seal: doorseal.com.au/fittingguides/d4-fitting-instructions – BMitch Jul 24 '11 at 17:34
I broke down and called an appliance repairman. Your initial assessment was correct - he reseated the door and the gap no longer exists. – Scott Mitchell Jul 25 '11 at 23:58
