Hopefully this is an appropriate place to post:
I had to use my generator today and it ran fine for about an hour but when I went outside to check on it, I noticed it was dripping gas from the carburetor! I shut it down and shut off the fuel and it looks like it is coming from a hole at the top of the carburetor. If I turn the fuel supply on, it starts dripping again. Also, the unit will not currently start.
I did drop the bowl and saw that it had gum stuff in it. Kind of strange considering I just cleaned it before the winter and had run it during the winter without issue.
At first, with the float pushed up, gas would drip down, indicating something wrong with that valve or gummed up SO, I used carb cleaner, cleaned the bowl and sprayed upward in to the carb. I also sprayed in to the hole that the gas is coming out of and let it drip down through. I moved the float back and fourth several times. Now it seems to work fine. If I let the float hang down, gas comes out to the bowl. If I push the float up, gas stops flowing.
I do not think there is gas in the float, but I am not 100% sure.
I still have the problem however- if I replace the bowl and turn on the gas, soon after gas starts leaking from the TOP of the carburetor through the hole up there.
float down, gas comes out
float up, gas stops
picture of the carb, but gas is shut off
gas is turned on, notice the gas coming from the hole at the top
This is a Generac 5500 Generator by the way and a Briggs and Stratton engine model 185432 0606E 99052149 by the way.
What do you think is wrong?
Welcome to the site. We have maintenance questions for lawnmowers and other gasoline-powered gizmos, so it's on-topic IMO. There's also mechanics.stackexchange.com where it might be on-topic too (disclaimer: I don't participate there so can't say for sure). – Niall C. Jul 16 '11 at 14:50
What's missing is a "small engines" SE site. – Jay Bazuzi Jul 16 '11 at 19:03
@Niall: I don't think they like small engines on Mechanics. You know how mechanics can be ;) Though I do believe you would be more likely to get a good answer on Mechanics, if you could get a mechanic to read the question without closing it that is. – Tester101 Jul 18 '11 at 1:30
It must be this model because Im having the same problem.fuel just pours out of carb five minutes after shutting engine off. – user25025 Sep 4 '14 at 17:10
Bottom line: your float isn't doing its job. Perhaps it's cracked, and thus doesn't.... float.
As the float comes up, it's supposed to close the needle valve. And you've shown that if you manually manipulate the float, the needle valve is working. So your float isn't floating.
Time for a new float, I'd surmise.
I had the same problem float was working I found needle valve was sticking. cleaned what looked like a fungus on valve. Generator now works great. – Robert Camille Jan 22 at 19:36
protected by Community Jan 22 at 20:28
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
