Tell me more ×
Possible Duplicate:
How to run ethernet cable through wall cavity
I've been interested in running a really fast hard-line network for a while, but the main deterrent has been installing the CAT-6 cable in the walls and installing face plates for outlets. I'm trying to understand exactly what would be required for my current setup.
It's a one-story apartment, not sure on the square footage, but I'd definitely do almost all of the cable through the wall.
How do I pass the cable through studs? Do I have to cut away at the drywall and drill a hole through each stud I want to pass through? Also, how much drywall will I have to cut away and patch? Will it be every stud? Is there a "from-scratch" guide available to instruct on how to do this?
What problem are you trying to solve? You really want 10G Ethernet? Why is 802.11n insufficient? – Jay Bazuzi Jul 4 '11 at 19:14
This is closed as dup because the question is really "how do I run low-voltage wiring?" and not "how do I run Cat6". Just in case someone comes looking for Cat6 info, I found this article describing some of the pitfalls to watch for: expresscomputeronline.com/20031124/technology01.shtml – Jay Bazuzi Jul 4 '11 at 21:13
@Jay, because I'm just that kind of a person. – TK Kocheran Jul 5 '11 at 21:07
marked as duplicate by ChrisF Jul 4 '11 at 19:53
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
up vote 4 down vote accepted
I did this yesterday, so it's fresh on my mind. :)
First, for your wires and whatnot, I highly recommend monoprice.com. Excellent products, and very affordable. I also found an excellent, power-saving 8-port 1Gbps switch on Amazon.
In a best-case scenario, you'd want to run the wires across the attic/crawlspace and then down/up into the walls. If there's any way to access over your head or below your feet, that's the way to go. In that case, interior walls are easy to get to, just aim right when drilling down! This is by far the best solution, since the only drywall disturbed is where you install the jack.
But as for exterior walls--forget about ceiling access, the combination of tight working spaces, insulation, etc. will make it impractical to do without opening the drywall and running across the wall. And in most cases, floor access will be just as hard.
For that scenario (across the wall), you'd need to open a small section of drywall (perhaps 3"x8" across each stud, and use a drill with a LONG bit to get through the studs at an angle. Then, like a ceiling-down or crawlspace-up installation, use a fish tape to pull the wire through.
You'll need about a 5/8" hole or so through the studs to get a CAT6 cable with the RJ-45 end on it through the hole. You can go a lot smaller for just the wire, but I recommend buying cables with the RJ-45 connector molded on--proper punch-down for CAT6 leaves a lot less room for error than 5 or 5e, and MonoPrice and others sell an excellent Keystone-style coupler so the wall-plate still has an RJ-45 jack, not a wire coming out of the wall.
Another option for across-the-wall installation is to run the wiring behind the shoe molding or the baseboards. Then, your run up to the jack can either be behind the wall (a short run that you should be able to fish relatively easily) or just up the wall (home improvement stores have cable channels to help tidy this up).
A third option for exterior walls is to run it in conduit on the outside of the home. Aesthetically, this is the worst option, but if the conduit is hidden by bushes or something where you need to go through the wall, it may be a viable option.
For jacks, I recommend a Keystone-type system combined with a low-voltage (orange and backless at Home Depot) old-construction electrical box. This combination offers the best flexibility for the future and easiest cable management (making the turns) inside the wall.
If you have thick plaster walls or shiplap behind drywall (common in older homes), skip the low-voltage box, you'll need deep, blue plastic boxes for old construction, and replace the screws that hold the wings with longer versions of the same, since those screws are only long enough for 5/8" drywall.
Other tips:
Always run two wires. One for what you're doing right now, and another (just a strong, loose wire without connectors) so you can pull something else through in the future easily without opening up the walls again.
Be generous with taping. It's always easier to remove electrical tape that is holding your fish tape to the wire you're pulling than it is to try to retrieve said wire if it come detached from the fish tape during the pull.
If you go through all the trouble to open and repair drywall, look at installing conduit so you don't have to do it again. – Jay Bazuzi Jul 4 '11 at 19:16
I think you'll find How to run ethernet cable through wall cavity should give you a good start on what some others have done.
If you have a more specific problem, please feel free to ask/edit.
I think your problem might be more easily solved by running an external conduit mounted to the wall, with the appropriate boxes for the connectors.
