I have a lamp shaped like a boat that has 2 separate bulbs. Dim bulbs in the cabin and a regular 45w lamp in the sail. The switch rotates to turn on either cabin, lamp, or both in that order. I need to replace the switch but don't know what to search for.
1 Answer
What you want is a switch that looks as follows:
This particular unit comes with pigtail leads that make it easy to connect into the existing wiring in a light fixture.
The switching configuration is specified as:
Single Pole Triple Throw, OFF-ON(P)-ON(N)-ON(N+P)
