I'm not what you'd call a handy guy, and now wife wants me to put up curtains. This task is reduced primarily to getting a bit of metal stuck to the ceiling.
I bought screws and anchors. The anchors are a bit shorter than the screws. The clerk in the store told me that's normal. After some soul searching, I managed to drill the holes as deep as the screws. At first, I was worried that the holes were too big, since I can put the plastic anchors in with my finger.
When I try screwing in the screw, I'm physically unable to turn the screwdriver about halfway in (at this point I'm unable to yank it out of the hole either, so I'm assuming that the plastic bit expands on the inside). I don't have one of those screw-driving thingies, but I attached a screwdriver instead of the drillbit on the drill I used to make the hole, and it just "jumps out" every time I press the trigger.
I'm confused. The only possibilities that I can see are as follows:
- I am not strong enough and the drill is in high gear so it can't be used this way.
- Somehow I managed to mix up the anchors and the screws.
Well, here are the culprits:
Oh, don't worry about the hole in the background. That one hit something shiny, so I abandoned it. Anyway, that's about as far as I can screw it the screw without losing my cool. Oh, it's my ceiling btw.
