Tell me more ×
I've got an off-line Hayward chlorine tablet feeder on my pool (it has a 1/4" hose that taps off some water from the pressure side of the pump before the filter, and it outputs via 1/4" line to the return lines after the filter).
This thing has a screw-top to seal the chamber where the chlorine tablets go, and it has a latch mechanism - if you screw it on far enough, it latches to prevent the top vibrating off.
This thing is only 3 or 4 years old.
At this point I can't close it completely (it's simply too tight to screw on any further). When last I did have it completely closed, it took me over an hour to get it apart. It doesn't leak, and various tests (unscrewing various fittings) shows that it is working.
Anyone know what's gone wrong here? It's almost like the plastic has changed shape in some way. Any idea how to fix it? It's not an expensive part ($60 or so), but it's only a few years old, and it seems to me it shouldn't need replacing already.
up vote 2 down vote accepted
The O-ring for the cap on my Rainbow chlorinator didn't last more than a couple of years. Perhaps you need a new one. My O-ring actually swelled and got bigger. I keep mine lubricated with silicone grease.
Yea, the O-ring was toast. Before I could get a new one in place it actually got so bad that the feeder was leaking and I had to buypass it. A new O-ring fixed that right up. Unfortunately, I still have trouble screwing it on to the latch point. I'm becoming convinced that screw-tops (for all their mechanical design advantages) are for the birds on pool equipment - they're just too much trouble to get open and closed properly. – Michael Kohne Jul 6 '11 at 23:35
I have the same problem with a brand new Hayward feeder. I use a rubber strap wrench to get it off, but even then it's killer. Since the top has the indents, I'm thinking there must be a wrench that is made for it. If I can't find one, I think I'll be making one (likely out of plywood).
I don't know if there's a wrench for that one. I know there is (because I have one) a wrench for removing the screw top lids on their pumps, but I haven't seen one for the feeder. – Michael Kohne Jul 28 '11 at 11:48
Just like any other threaded thing, try the following:
  • clean the threads
  • use appropriate lubricants or sealers
  • replace any seals (sounds like you already did O-rings)
  • check the threads for damage
  • unless the manual specifies that you have to use some force to tighten the device, you shouldn't force it
Yep, did all that (the o-ring is the only seal). The thing did NOT require force when new. My guess is that either due to temperature cycling over the winters, or due to chemical attack from the chlorine, the thing has expanded, causing the problem. – Michael Kohne Jul 28 '11 at 16:22
Do you think the cap has expanded or that the container has shrunk? I assume this is a PVC-like plastic which has a bit of natural slickness to it. Is there a lubricant or restorative you can use? Perhaps teflon tape? – Freiheit Jul 28 '11 at 17:10
If it is filled with water, you are not only fighting against the original friction and any other junk that might've made the seal stronger over time, but you're attempting to unscrew something, which makes it withdraw, forming a vacuum.
Try to get some air into it by opening up the air pressure relief valve atop your filter, or by draining your filter. Then whack it with some moderate force with a screwdriver. Also, if it has a handle on top, you could use a long bar/screwdriver/whatever to create more leverage.
If you manage to get it off, lube it up with regular ol' pool lube or T Plus 2 pipe dope (liquid teflon).
Also, tablets pretty much suck. They mess up your chemistry pretty bad, putting too much cyanuric acid into the pool, which NEVER goes away (unless you drain the pool) and forces you to put more and more chlorine tablets into the pool. Unless you drain your pool yearly, your pool's chemistry is in a slow but irreversible death spiral. If your pool is compatible with salt, salt water chlorine generators are far superior and are highly recommended.
