I'm new to the amazing wold of electronics and starting out small. I think... Early 2010 me and the wife bought a house that was build in 1979. Now I started replacing light switches and encountered something that appears to me as a weird setup.
This is a simple schematic of what I managed to figure out so far:
I know this makes no sense at all. What I try to explain is that I have 5 switches that turn on the same light. Each switch has 3 wires, a red, black and blue wire. The light bulb has 2 wires and a ground wire.
The Switches
I can't figure what kind of switches these are and I can't find the location where the yellow wire from the light bulb is connected to the hot wire.
Below is a picture I've taken from the switch.
The mechanism works like this: When the button is pushed down, I measure zero~ resistance between the top-left and the bottom connection point. Once I release it though the resistance is infinite again. All the other connections always measure infinite resistance.
Any pointers on the type of switches or how this could all work is greatly appreciated! I want to learn how all this stuff works and I have a multimeter to measure current/resistance and a lot of other things I don't know much about.
Update
Maybe I shouldn't have drawn the schema as it adds to the confusion but the point is that I have 5 switches with each 3 wires connected. A red one, a blue one and a black one. From what I've measured:
- Between blue and red: 230V
- Between blue and black: 230V
- Between red and black: 0V (These short circuit if you would connect them)
The button on these switches is indeed sort-of like a pushbutton. You push it down and it comes back up automatically. From what I've measured is when pushed down there is no resistance but once it's back up (you release it), there is again infinite resistance.
What I would like to know is how could this be done? What sort of switch is this as I have no clue. A cross switch would need four wires and I only have 3.
