Only during summer and only when the sun is close to the horizon the light from the sun confuses my garage door opener and in order to close the door I have to hold down the wired button which is a real pain if I'm leaving.
A friend suggested I use toilet paper rolls (or maybe some PVC) to shield the sensor from the sun and direct the beam to the other sensor and that's a good idea but it'll mean I have to change how the sensors are mounted to the track and move them out a bit. Just moving them back might solve the problem (since they'll be blocked by the walls).
Any other suggestions? Is this a common problem?
Amazon has
