Tell me more ×
I was walking home the other day and came across a group of workers installing pavers for a driveway. The thing that caught my attention was one guy who was filling in the gaps (about 3/8 to 1/2 inch) between the pavers with a caulk gun loaded with a tube that contained some kind of tan material.
I've used sanded caulk before, but only indoors. I'm assuming that this is something similar, but designed for a slightly harsher environment.
What was this material, and what are the advantages and disadvantages to using this to fill the gaps between pavers?
Could it have been concrete? go poke at your neighbors driveway and see if the material is hard (like concrete) or softer (like sand). – Tester101 Jun 22 '11 at 15:36
Well, it was flowing out of the tube as if it was pliable, like caulk. Do they put concrete (or concrete like material) in tubes like that? – rsgoheen Jun 22 '11 at 16:29
Not that you would buy at the store (I don't think), but the guys doing the job might have a rigged up system they invented to save time. It would probably make it easier (less cleanup) to put concrete between each paver using a caulk gun, than to try and get it in any other way. Although I could be completely wrong about it being concrete, so... – Tester101 Jun 22 '11 at 16:33
I wouldn't think it's concrete. If they filled in ALL the gaps with something rigid like concrete, that will prevent natural expansion/contraction, and this "grout" will crack and fall out, or the pavers themselves could crack if the stuff is as strong or stronger than the pavers' base marterial. – KeithS Jun 22 '11 at 16:46
I can't think of a single advantage over polymeric sand. – DA01 Jun 22 '11 at 20:47
1 Answer
up vote 2 down vote accepted
It could very well be an outdoor sanded caulk, meant to seal the gaps in the pavers to prevent weeds and water, which can disturb a nice level surface of pavers over time. I mean, if you'd trust a 1/2" bead of general-purpose silicone caulk to seal flashing on your roof, I would trust it to perform similarly in most any other application.
It could also be a grout-like substance, used in much the same way as for tile. This kind of material would be more rigid, and I wouldn't count on it lasting very long if you get cold winters; it'll crack, loosen and eventually crumble away as the pavers, and the ground itself, shrinks and expands.
