It's kind of tempting to use vegetable oil for lubricating door hinges and other similar basic mechanisms around the house - vegetable oil is readily available in almost any household. However I always hear it's a bad idea, but could never find any details of why exactly it is a bad idea.
What exactly happens if I use vegetable oil for basic mechanisms lubrication?
up vote 7 down vote accepted
  • Vegetable oil will gum up, attract dirt and dust, and eventually end up a huge mess. DO NOT use it.
  • Mineral oil is a food-safe oil not normally used as a cooking lubricant, but it is the go-to for replenishing woods and lubricating mechanical parts of cooking utensils. It won't gum up, and is OK to use in a pinch.
  • Most machine oils are a bit thin; they'll get into crevices like in door hinges, but they're lighter-weight and more volatile, and will eventually evaporate or work their way back out.
  • Silicone sprays are great for metal-on-metal, but they are incompatible with some plastics, so read the label carefully.
  • If you can take the mechanism apart without destroying it, I would recommend a silicone grease out of a tube, such as Dow-33 (available under many different brand names; you'll most likely find it as a pneumatic tool lube because it doesn't hurt o-rings). It is nonreactive with all plastics and metals, and is a thick-ish grease which stays where it's put. A little dab'll do ya. Only trouble is you have to be able to apply it directly to the surface to be lubricated; it doesn't wick into crevices like an oil or spray lube.
Vegetable oil will gum up, attract dirt and dust, and eventually end up a huge mess. Describing the average glow fuel powered (Alcohol/Nitromethane/Castor Oil mix) RC model airplane after a day's flying. Seriously, get into the hobby and you'll be put off the idea of using vegetable oil for lubricating anything. – Fiasco Labs Sep 18 '14 at 2:06
Oil of any kind is the wrong lube to use on hinges. Oil, WD40, or any petro based product wets the hinge surfaces and will collect dust and dirt. I always recommend dry silicone spray. Silicone works great, won't harm surrounding finishes etc. Some folks like graphite, but I find it a bit messy to use.
i also like teflon spray. it resists weather very nicely and doesn't discolor paint. – longneck Jun 21 '11 at 23:47
Vegetable oil should NEVER be used to lubricate mechanical parts. It always leaves a solid deposit which later will be stuck to the parts you wanted to lubricate.
It should be noted, different oils have different rates they break down, viscosity, weight, etc... different kinds of oil's exist for different needs.
I've never heard of using silicone on a hinge; wd40 has always been my go to. will look into that.
Vegetable oil would probably decay over time and begin to smell; stain the trim surround.
In cooking, different oils have different flash points (the point where it catches on fire), smoke points. you wouldn't use cooking oil in a gasoline engine for this reason. Its flash point is to low.
The smell would be the biggest annoyance. Cooking oil is designed for...cooking...not lubrication. It also goes rancid, which isn't something you'd want as an odor in your house. – DA01 Jun 20 '11 at 14:12
Food oil is lightweight, goes rancid, and breaks down quickly. The only food-safe oil I can think of that won't rot is mineral oil like what you should use in a cutting board. – Peter DeWeese Jun 23 '11 at 2:12
Jojoba oil is a waxy oil that can be used as a lubricant. It is the only vegetable oil that never gums up and never goes rancid.
