I'm doing some remodeling in our basement, and came across the following (see pictures). It looks like the contractor simply wrapped tape around the conduit to secure the box to the wall.
How are exterior boxes usually secured to an exterior wall? What is the "correct" way to prevent weather and/or critters from accessing the hole in the siding? I saw a similar post that mentioned caulking the box to the exterior wall, but is that how it's usually done? Are there any IBC codes that apply in this situation?
inside outside
up vote 5 down vote accepted
The IRC or the NEC doesn't apply here, common sense does. What you need to do is apply a paintable silicone acrylic or silicone caulk to the back of the box and around the entry hole before you screw the box to the wall. There should be holes inside the box or external ears for mounting. The idea is to stop water from going behind the box and around the conduit into the wall. Don't be afraid to use it, you can wipe off the excess with a damp cloth. Good luck.
also, for the wire itself coming out of the conduit, they make plastic inserts to protect the wire. – longneck Jun 13 '11 at 2:03
yes there are plastic bushings you can use. I see from the pic that it is old wire. I would give it a good wrapping of electrical tape where it exits the conduit as well. Looks a little frayed. – shirlock homes Jun 13 '11 at 4:25
The cable is old enough that it probably doesn't have a ground wire, so it should be replaced. – Brad Gilbert Jun 25 '11 at 3:32
You can go the caulking route, but I personally like a putty like material called duct seal for sealing many of my protrusions (click the picture for the product link):
duct seal
When you work it in, leave a lot of it around the conduit outside of the wall so that when you reattach the box to the house, it squeezes the material to create a weather tight seal. Should you decide to caulk around the perimeter of the box, I would leave an opening at the bottom of the box to allow moisture to escape. Because more importantly than keeping the spiders out, you want to avoid trapping moisture and causing wood rot.
The best way is to clean the area behind the box on the outside wall.. some sand paper make it kinda' rough. Use water resistant silicone and apply around the pipe area and on the edges of the square. Use screws and faster the box to the (looks like wood so use some longer wood screws about 6) and fasten it tightly to the wall. Apply water repellent silicone to the outside permiter of the box after you fastened, use your finger to create a curved area- don't be shy , all around the box one with no breaks. On the inside you can just put more silicone in the pipe where the wire is running.. will stop any spiders and possibly some minor amount of dampness.
This answer is based on experience. Home regulations only mention that exterior boxes need to be well insulated from water and in some countries grounded to a earth leakage breaker is applicable.. especially if you get freezing winters. Otherwise this box will stay fastened to your wall forever and ever.
Completely sealing the conduit is fine, but I wouldn't seal the entire perimeter of the box to the wall. If you decide to seal any of the perimeter, at least leave some opening in the bottom to allow moisture to escape so you don't create a moisture trap. – BMitch Jun 13 '11 at 12:30
I suppose it depends on the climate. In south Africa it will be ok in Britain. Sure. It's always rains. – ppumkin Jun 13 '11 at 21:30
